U
underpar12
hi can anyone help , just been called to luxury 4 storey flats.the problem is the internal staircase lights,there is 4 floors with 4 p,i,r, sensors and 30 lights in the staircase.any pir turns on all lights from any floor it has a overide swich grid and a emergency grid switch. all pir have been changed within the last 16, months. the problem is the lights are on permanentley, have checked grid switches there ok,have disconnected all pirs,turned all times down.connected one pir up at a time still on permantley,should i start dropping light fittings know to see and check switch wire is not touching the perm live
