Problem with PSSC on three phase supply | Page 3 | on ElectriciansForums
Discuss Problem with PSSC on three phase supply in the UK Electrical Forum area at ElectriciansForums.net
sparksburnout
Nearly Esteemed
Notts
I have a domestic premises (it was once a shop) that has a three phase supply, although only one is being used now. I am using a di-log 9083P tester, and when doing a Ze test am getting 23KA as the reading for PSC, with 0.01 ohms as the loop resistance. I am getting a Ze of 0.35 ohms and a PFC of 565A. The values for PSC and L-N loop impedance seem unbelievably low to me? I am not sure where the local transformer is but it is not next door, I think it is about 400yds away. System is TNS. I have looked at the thread in the I&T forum, and used the method of inserting an impedance in the earth lead of the tester, but I am still getting the same readings, which as far as I can see you would, as it is for low Ze not low PSC. I have used the tester on about 3 other installations, and it is giving expected results. Could it be possible that these values are correct? In which case the main switch and breakers are well underrated!!
I used to get around a lot but haven't been able to for the past couple of years cos I've not been well.
I always wanted a good camera outfit and after about 30 years finally got it - all packed in a big fluck off rucksack that I can't carry .......
go on then. keeping us in suspenders, what camera?
Meanwhile back at the OP.
Might sound silly but how are you off for charge in the battery pack? Many testers start to give really daft readings if they're low.
I also think you may need to check your reading as it does not work out to 23Ka
Furthermore, a Ze of 0.1 ohms at the distance you quote from the transformer is unlikely in my experience. I once did a rewire less than 50 metres from one and the reading I got was 0.47, considering how streets are wired this isn't beyond the realms of possibility but I checked it with different testers both very recently calibrated and they agreed.
I'd definitely be checking those batteries mate.
Canon 30D
Old(ish) but does the job - a bit like you Tel.
Bag full of assorted lenses -Canon & Sigma, Sigma flashgun, Manfroto tripod and a monopod (one legged tripod) bits & bobs and I can't lift the bloody thing.
nice. i have the 10D. even older.does everything i need, though. only gripe i have is the size of the LCD screen 1.8".
Reply to Problem with PSSC on three phase supply in the UK Electrical Forum area at ElectriciansForums.net
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
FFS - popped it apart, found the same issue and thought I'd update... You guys were already there!
