Problem with sensor no reason out signal when power on | on ElectriciansForums
Discuss Problem with sensor no reason out signal when power on in the UK Electrical Forum area at ElectriciansForums.net
Serbia
I have photoelectric sensor (6-36 V), PNP, NO+NC and when I power it for first time, it generate output signal with no reason (there is no object to detected)
What is the reason for this and how to deal with this problem?
Reply to Problem with sensor no reason out signal when power on in the UK Electrical Forum area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
Thank you, what would be the advice for me to do in this scenario? I've also seen circuits tripped in past from other things such as 1500VA step...
