Hi Folks, I've had a strange and frustrating day today. Installed an MK split load Consumer unit to replace two rewireable fuse boards.
Earth system is TT 14.5 ohms PFC is 1.86 M ohms I've split the load over two 63A 30mA RCd's as follows (left to right from main switch):
So I double checked that I had wired the board up correctly( no neutrals put to wrong neutral bar, RCD's wired as per manufactures instructions, no rings crossed...). Then tried just having the kitchen sockets on one side with the oven or the downstairs sockets or the spur sockets on their own. Still the wrong RCD trips!!
Ditto using upstairs sockets only.
Ditto using spur sockets on side 2
So then I took the lighting circuit out of the puzzle. Same result.
The only area I am uncertain of, is the cable from the main cut out. This runs as a single cable from the top of cut out to the meter. I presume this is in fact two-in-one which seperrate at the meter?
So can anybody shed some light please, before I spend another 3 hours scratching my head and cursing!!
- Oven, Downstairs sockets, Spur sockets, Lights (they are all on one circuit!)
- Shower, Kitchen sockets,Upstairs sockets, Spur sockets
