Problems what to do? | on ElectriciansForums
Discuss Problems what to do? in the Electrician Talk | All Countries area at ElectriciansForums.net
L
leokiss
Ive been asked by a friend to look at a job which involves a new DB i think!
Its a garage with a 3-phase supply the DB is full.
They want a feed for a new ramp.
Im thinking can i tap off the DB(supply)and have a MCB in an enclosure as a possible out.
But overloading is a worry with DB been full. Im thinking if i clip the ampmeter round supply with everything on,and if ok with main switch and fuse i can do the above.
But i ain't too sure any guidence is welcome,cheers.
It depends on the readings you get from the load test, but if all is ok I think I would do the following. Divert the existing supply cables into a new main switch or switch fuse. On the secondary side you can either take the cables into a small bus bar chamber (expensive) or into some double deckers. From here you can install a new board and re-feed the old one. This also gets you over the regulation concerning one means of isolation for the whole system. This is also dependant on having enough space. Does the above make sense??
Ye cheers apart from im not sure what double deckers are? And Busbar chamber does sound expensive any ideas on the price?
Double deckers are those big black tail connector blocks. You get them with one common terminal or two, the latter being double deckers. Also known Henley blocks
Another way is to fit another DB next to the original.
Remove 3 circuits from the original DB and use these fuses to supply the new DB.
The 3 circuits you removed from the original DB can be installed in the new DB.
Reply to Problems what to do? in the Electrician Talk | All Countries area at ElectriciansForums.net
Hi there, long time lurker, first time poster here. Straight down to it.. A friend asked me to add some sockets and additional lights to a small...
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
Thought I'd update this. Finally had my assessment today. I chased them on Friday morning as it'd been about 10-12 weeks since I'd actually made a...
This potential client seems to be making progress in terms of being interested in proper chargers and answering my query questions. I have also...
