Problems with LED Lights | on ElectriciansForums
Discuss Problems with LED Lights in the UK Electrical Forum area at ElectriciansForums.net
scott
Not sure this is the right place for this but i'm new. There are 3 spotlights in the bathroom and all fitted with GU5.3 4.5w LED bulbs. These bulbs flash bright when turned on and then dull down very low. If I replace one of the bulbs in the bathroom with the old GU5.3 5.5w LED bulb, the other two instantly brighten up. There is also a extractor fan in the circuit. Not really sure where the problem is located and could use a few pointers.
Reply to Problems with LED Lights in the UK Electrical Forum area at ElectriciansForums.net
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
Flange and nuts in the same sentence. Jeez I really must start acting my age.
