Problems with MK light switch quality | Page 2 | on ElectriciansForums
Discuss Problems with MK light switch quality in the UK Electrical Forum area at ElectriciansForums.net
Gavin John Hyde
Patron
Somerset
Has anybody noticed a decline in the quality of Mk accessories of late?
Where possible i stick with Hager but have used up my stock, sometimes its customer insist on Mk or Wylex as thats brands they know or already have and want it to match.
In the last month i have had several sockets with screws that would not move for love or money, so couldnt be used. these were replaced by the supplier no questions asked.
Also had light switches with various issues, some had screws in the terminals again not moving, they were off centre and jammed or too tightly fitted in the factory. had i applied any more tension to try to get it working the thing would have split.
Had 2 that just plain did not work, current wouldn't go through when switched on! Had another where there must have been a loose connection inside as it made the light flicker and created a buzzing sound when up close.... swapped switch out no flicker or buzz..
When in the suppliers they said they have had quite a few Mk bits returned recently... Makes you wonder if Mk have farmed out production to a third party and quality has gone out of window for profit...
Thankfully my stock of MK is now depleted
I took out a old MK socket today with lovely brass terminals on the bag, you could have put a AAA battery in them, with nice easy to turn screws. Compared to the modern stuff it was built to last, the plastic on it is like kryptonite, a modern one would crack if dropped on the floor, this old one took a blow from a hammer to loosen the paint and plaster around edges and still didnt break.
I had to take a hammer to an old MK socket a few years ago as the tiler had tiled it in, that took a fair few whacks to get it to even split.
MK stuff has been going downhill for many years never really used their accessories since they produced the sockets with the twist shutter. I'm sure in the late 80's there was an NHS HTM issued on them stopping there use on health premises.
In the 1960's some of their output was assembled by home workers one of my relatives lived near the factory in Edmonton and when visiting them we quite often went to the factory to collect a box of plug top parts for assembly at home, I vaguely remember they paid 2d or 3d per plug top assembled and each box had parts for 1000 plug tops
This topic was recently being discussed at the local wholesalers, the main question was how long before MKs drop in quality causes them to go bust. They have certainly lost out on thousands of pounds per year from us in the past 5-6 years.
The problem MK has is that it was always seen as a premium product and while it's current pricing level gives the impression it still is a premium product unfortunately the product quality doesn't always reflect this. I doubt MK will go bust as long as people still believe it is a quality product which may only be because of it's price
25 - 30 years ago the big players in the accessories market were MK and Crabtree and most wholesalers stocked at least one brand both were regularly specified by architects
Now how many wholesalers have either brand on the shelf, architects and consultants who specify MK tend to be the close to / semi retired types whose practices have just carried through their old traits of MK is best and have never looked at the current products
When you look at price when I first started in the industry a double socket and a back box cost around ÂŁ4.50 ok there is a lot more automated production now but the same can be had for as little as ÂŁ2 now, MK and Crabtree are priced to be a more premium product but chances are they are coming down the same production lines as the cheaper alternatives
I got an mk light switch the other day as a replacement for a friend. (He'd broken an existing one)
Turned up at his, got it out of the packet and one of the terminal screws was already chewed up right out of the packet.
Reply to Problems with MK light switch quality in the UK Electrical Forum area at ElectriciansForums.net
Back to the Men's Shed today to complete the installation of the 4 LED battens in the attic. These were a joy to fit, having screwed the units to...
Figured things out. Thanks for the help. Original wiring only had one wire going to the bottom of the left switch. Found some spare wire and...
