Hi chaps,
This may sound stupid, but as many of you know, I'm fairly new to the game.
I wired a few lights earlier from a loft space. Had a couple of rooms, each with 2 fixtures, supplied via 2 separate switches. Simple wiring of course, all in 1.5mm T+E from the installed lighting circuit.
Only problem is that I put everything through a single junction box and it looks a mess...
I used a standard 2g surface mount box with choc block and crimps to make the connections. Everything works and tests ok, but I'm just wondering what products I could have used to make the job look more professional. To be honest, at the moment it looks like spaghetti...
Can anyone recommend products that I can use to simply make my junction boxes look a little more "professional"!
