Discuss proportional pressure control in the Talk Electrician area at ElectriciansForums.net
Thanks for helping me!If I had to guess,
Terminals 11,12,13 may go to a pressure transducer
14,15 analogue output to a motor or valve that increases or decreases the process pressure
Terminals 3 and 4
May be part of the safety circuit to stop the process if there is a failure.
Please take this as a BEST GUESS FROM THE PHOTO
do you have a machine wiring diagram?
If not, you may have to physically trace each cable to find out what it’s function is.
Is there a problem with the machine?
It is a control panel of Press Brake machine from 1980Hi,is this part of a "smart system " management installation?
The makers of this type of kit,are not always very forthcoming with the schematics,preferring to keep fiddling "in house" and getting the maintenance bit,themselves,or their agents.
Can i ask how old it is?
Reply to proportional pressure control in the Talk Electrician area at ElectriciansForums.net
