pro's advice needed | on ElectriciansForums
Discuss pro's advice needed in the UK Electrical Forum area at ElectriciansForums.net
daiplayer
Working in a house , have already rewired the kitchen , have been ok'd to rewire first floor lighting .( due to poor condition)
Am trying to keep costs down for customer when bringing house wiring up to standard.
Will be doing some more remedial works but am trying to suss out whether they need bonding upgrade.
Its a TT with a Ze of 207 , ( high i know ) what can i do about this ? inform dno :- convert to TNC-S?
Any way : PEFC : 1.11 a , ( LOW ) PSCC 1.2KA . HIGHEST Zs in house 3.43 , existing bonding 6mm .
As a rule of thumb ive heard of people using 0.5 of main supply tails : 16mm .
However if i inform the DNO of the high Ze and they convert to TNC-S , pefc will rise to eg: 230/0.35 : 657A min.
Any ideas ? or can show me how to do the adiabatic with this ?
The DNO will not care about your Ze value. That's your problem! But 207ohms isn't a hanging offence.
What's the protection for the installation. 30mA rcds on all circuits, or what?
I agree best to ask for PME but you'll probably have to wait for some weeks.
re
Don't understand, what are you tring to calculate, the size of the earthing conductor?
Going deeper will without doubt get you a better reading, more importantly it will be morelikely to be stable. TN levels are achievable but you need a bit more work to get them,
Go for the thickest couplable rods you can get your hands on mate
The 6mm earth and 6mm bonding will most likely be fine if the installation is left TT
Indeed, the most it is going to carry is 30mA! That allows your Ze to be as high as 1666ohms (not recommended).
Re adding a rod: If you go that route it will need to be at a distance away at least 3 times the length of the existing rod - there's some interesting papers on the 'net' if you can be bothered. Including here http://www.electriciansforums.net/e...electrical-forum/42851-earth-rod-spacing.html
As stated above, it's better to bang in two new chunky rods coupled together. Doesn't work if you are sitting on a lump of granite, however!
your main earthing conductor on a TT system is fine at 6mm as long as it's not buried unprotected. as previous posts, go for a longer rod, at least 1m from the biulding.
Reply to pro's advice needed in the UK Electrical Forum area at ElectriciansForums.net
