Prosecution | Page 5 | on ElectriciansForums
Discuss Prosecution in the UK Electrical Forum area at ElectriciansForums.net
tigerpaul
Tadley
We had our ECA assessor visit today and while we were chatting he mentioned a case in London where a contractor had done an apartment block. There was a fan in a bathroom which had gotten stuck and the motor had caught alight and caused a major fire. Everything he'd done was as per BS7671, except however he hadn't fused the fan down to 3A as per the fan manufacturers instructions. Now this contractor has been prosecuted.
Now how many times have you seem a bathroom fan fused down to 3A? I haven't at all, it's always just the 6A Mcb providing protection.
If it is true about fans needing 3A, then if its a new build you could take it from its own circuit...i fear for this though, wont be long before literally everything will have its own dedicated circuit.
in some countries in europe, each circuit in each room is fused separately, imagine a house with 13 rooms, could easily be 30 circuits,all rcbos, oh the cost of a CU change, happy days lol
this will be 19th edition
Elrick, so the solution is either on its own 3amp mcb, or having a fuse spur next to the fan isolator? The latter is going to have to take some working out in my head.
This thread has been a real food for thought. Honestly never ever thought of fusing a fan down, ever.
not that difficult really, just put FCU before bath light, assuming its 3 plate, then alls good, fan isolator in normal place,
question is, what if your fitting a 12v fan, and the transformer has a 100mA fuse built in
If it's a new build you could easily work the circuit on a 3amp breaker (all the lighting in my house hardly goes over 1 amp), especially being all the pendants should (more or less anyway) be low energy. MK is the only manufacture I've seen selling them en masse but I'm sure there will be others
And I'm with the general consensus that the fan would of burnt out long before the fuse thought about blowing :lol:
A total load of rubbish! If you stall one of them tiny fan motors, there's no way it could cause enough over current to start a fire Come on get real!
Seen a few burn out in panels before (industrial) and they do literally melt away to nothing.
A few have caused fires in the past and actually thinking about it they were fused inline and the fuse never blew!!!!
Usually though in those type of panels you get a 240v/110v supply before the main isolator so you can use panel lighting/fans/sockets etc so they do get rated up a bit.
Reply to Prosecution in the UK Electrical Forum area at ElectriciansForums.net
