Protecting 16mm tails | Page 2 | on ElectriciansForums
Discuss Protecting 16mm tails in the UK Electrical Forum area at ElectriciansForums.net
N
NickD
Got a domestic install with client requesting CU upgrade. Tails are 16mm, EC 10mm, and buried in structure between meter and fusebox. Rating of DNO cutout fuse not known. Ordinarily I would upgrade the tails & EC to 25/16 as a matter of course (domestic load includes an outdoor hot tub as well as the usual sockets/cooker/immersion type stuff, don't recall if electric shower present) but routing them through the existing route of the 16mm tails looks like a non starter and I can't see a practical alternative route. The meter box is small and absolutely chocker with no space in there to add a separate fused cutout. Adding a fused cutout next to the replacement CU (in downstairs cloakroom) would probably be doable but cluttered/messy.
Installing a 63A MCB in the new CU, suitably labelled, immediately downstream of the main switch and feeding all RCDs/final circuits...good/stupid idea?
Nick the DNO fuse is there to protect their kit so if a 40/60/80 amp fuse has been quietly getting on with the task and not bothering anyone what possible motivation could they have for changing it? I've got a 16 amp RCBO on a radial circuit in my house, it's been doing what it does for about 6 years now, think I should change it for a 20?
of course you should change that 16A for a 20A. what about when you add the 10kW shower to that radial?
Nick the DNO fuse is there to protect their kit so if a 40/60/80 amp fuse has been quietly getting on with the task and not bothering anyone what possible motivation could they have for changing it? I've got a 16 amp RCBO on a radial circuit in my house, it's been doing what it does for about 6 years now, think I should change it for a 20 just for the hell of it?
I don't think you're pretentious by the way, wrong, misinformed, ill advised perhaps but not pretentious :)
I can't think of a reason, but that doesn't mean there isn't one. Big organisations move in mysterious ways. I would be happier with some kind of assurance that I am perfectly within my rights to rely on the DNO fuse to protect the tails.
20 is a rounder number than 16 if you tend to think in decimal?
Are you sure you're not ill advised when you advise me that I'm being ill advised? ;)
Nick, just admit, you’re milking this job by adding totally unnecessary work.
Someone had to say it, it may as well be a grumpy git like me.
If I was going to milk the job, I would have just got on and milked it without asking about it. Actually I just want to do an engineeringly-correct job, if that's a word. If it suits you to believe that milking it is my motivation then that's your prerogative. I could think of a darn sight more lucrative ways to milk this job than bunging in an OCPD, if that was my inclination.
Client at a job the other day had agreed a board change in order to extend the socket ring circuit. However with the fusebox cover off it became apparent that the standalone RCD next to it was protecting the socket circuit in question, not the shower circuit as advised. RCD was in good order and so was the socket ring circuit. Did I milk it by proceeding with the board change? No.
Non of your arguments have any credence yet you persist in them.
Why?
Forget any arguments you think I'm making then and please just answer my question; do you consider it is entirely justified and good engineering practice to rely on the present rating of the DNO's fuse to protect the consumer's tails?
Reply to Protecting 16mm tails in the UK Electrical Forum area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
