Hi all
Been in electrical/electronics for many years and am now semi retired but keeping my hand in, but is it just me, my age or what but back in the eighties / ninties nothing seemed to change that much and yes there was far less choice in fittings. Having spent more time in industrial than domestic and always needing answers I prefer radial circuits over rings but in industrial running singles I would use the same CSA for the CPC as the other conductors so why in 2.5 and 4.0mm T&E is the CPC only 1.5mm?
To disconnect a 32amp protective device requires a fault current greater than a 1.5mm can handle so is the reliance on the RCD, ie in theory the RCD will disconnect before the full fault current flows? Seems like relying on the unknown.
