Proteus rcbo Went bang | Page 2 | on ElectriciansForums
Discuss Proteus rcbo Went bang in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Worcester
Existing proteus rcbo went bang,any one had a similar problem,I haven’t switched back on yet.
The DB about 10 years old,don’t need this hassle.
See the clean 6A MCB in this photo - I fitted this a few weeks back...
the previous one gave up the will to live - as you can probably tell, the CU had suffered some water ingress .............. from the old leaking bath above which has now been all replaced
A nice shiny new CU has just been fitted!
Was going to say that bus bar looks iffy
I wouldn't touch any proteus materials that's are cheap and poorly made. They put in so little effort that the rcbos and mcbs sometimes don't even fit properly in their own boards
Proteus and M2 are not the best, but Hager and Wylex are equally poor in my opinion. The only really decent board is Starbreaker, everything sits straight, and there is no possibility of installing a device incorrectly as is the case with both Wylex and Hager. With Wylex the whole assembly slides on the din rail, you have to make sure nothing moves during connection or the cover wont fit, junk.
Reply to Proteus rcbo Went bang in the UK Electrical Forum area at ElectriciansForums.net
Yup will do exactly that when I'm back down there. Thanks for the help
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
