Proving unit | Page 3 | on ElectriciansForums
Discuss Proving unit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
My thinking is that the proving unit is the known supply and therefore should be used prior to any testing, I understand the veiw that how do you know the proving unit is ok, but you could go round and round this till the coos come home
I believe we may have just discovered the basis of ...............
... PERPETUAL MOTION !!!!!!
Hi guys,met Dave this morning and sorted him with a proving unit,he,s a sound guy just a little bit uncertain on some things,we,he all been there so let's try and cut his him a bit of slack,after all we,be all been there haven,t we
Agreed Phil and it not road best travelled alone something I think some members forget, also the underlying object of a forum is a exchange of information and frank exchange of veiws
without prejudice
Pict
I've found I've never needed to use a proving unit as either I can meter the incoming tails (as mentioned above) or just do a 250v IR test on my voltage detector, don't see why I should spend £60+ when I don't need to...
you guys know my time is done on the tools now,but I remember how hard it was when I started,just glad I was able to help out a fellow sparky by letting him have a proving unit and lamp that I didn't need,at a fair price.It,s hard enough these days trying to find work these days and the cost of kit is ridiculous at times.
When I was an apprentice it was either a neon screwdriver or a lamp with two bits of wire,but mostly proved to be dead if the fuse was out,switched off or the lights went out.
If I dont have a tester on me and they tell me to just do it, the earth falls out and lands on the line :p only on domestic ofcourse
...and just for devilment,a proving unit provides a known,reliable voltage source....just like the DNO does....although,THEY can go faulty....just like a faulty proving unit...the circle of conflict...
Reply to Proving unit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Great, then I am a bit bemused why you posted your original question. You need to stop doing any work that you cannot properly test, safety is...
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
