H
highspark
How do you guys pull your cables through conduit. What have you found the best method.
im really old school,i use my eyes..tho has anyone noticed even when you use a laser or a level it still looks pisd compared to anything else thats been previously installed,thats when i use the good old fashioned eye to make good.:stuart:
i am replacing a 6mm cable for a 10mm cable this week through an old system of conduit which im assuming is a 25mm diameter but in case it is full up would it be easier to run single core's in instead i'm wondering. which if ive aready bought the twin and earth i can splice the doubled insulation off remove it and use the 3 single insulated if it is already mechanically protected surely?
I would imagine pulling a 10mm t&e through conduit would not be much fun especially if there are other cables already in the tube and/or if there are a lot of bends to pull round. Even with inspection boxes you will struggle with t&e in my opinion. Unless it is a straight run I would definitely use singles. Cant you take the t&e back?
Cheers Andy your a mind reader I was thinking this today. I am going to buy the singles and a length of single 2.5mm2 cpc. I havent bought the T&E yet luckily! Although i supposed it wouldnt do no harm stripping the outer sheath of to use the singles inside if i had of bought it.
No I havent to be honest with you. well what someone has told me is that will be fine. its for a 10.5kw load 50a mcb and 10mm2 conductors.That CPC is a bit near the bone, have you checked if it will be man enough
