Discuss Push fit or lever wagos ? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
not got one of it im afraid well not at the mo , im going back there next week so ill try and get one for you , they are a bit pricey especially the green and yellow ones so ive used blue and the gray ones and ill be honest i did it in half the time of using normal din connectors as theres no screws just push them on and move to the next very very good so saying the money in the time it takes to install
i get mine for about 70p each from the electric ctr and they seem as good as the wago ones. if you want a couple of samples let me know and i will order some in
Doing it for myself and time is one thing i have plenty of so price is a bit more important to me - as long as the quality is ok. Probs going to use these(Electrifix) at about 44p each - slower but should do the job well enough. What did you think of the Wago enclosure - space and access wise for cables?
they are quite spacey but i have to admit i tend to use adaptable boxes and cut the holes to suit the amount of cables im installing and the use an armoured cleet to secure them , im sure ive used some of the electrofix ones and they were quite good but it was a while ago
What are peoples feelings regarding using wago's for lighting without an enclosure?
Hi Nick, you got a photo of that,
Reply to Push fit or lever wagos ? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
