Putting a chandlier up | Page 2 | on ElectriciansForums
Discuss Putting a chandlier up in the Lighting Forum area at ElectriciansForums.net
There are wood laths all across the ceiling. The trick is to screw through the white plaster hopefully into a wood lath behind. If the screw doesn't get a fixing, you move the metal strip and try again! By changing the angle of the bracket compared to where I've drawn it, you should be able to screw into the wood you see.
If the light is heavy, you need to find a joist to screw into.
[ElectriciansForums.net] Putting a chandlier up
I'd turn the bracket 90 degrees to be parallel with the centre of the lath that's visible - although it could be better to spread the weight across two. I hope the OP gets it after all this , thank god there aren't 3 or 4 cables present. :)
Oh thanks guys this is brilliant.
I really do appreciate this.
I hope the wood laths will support my chandelier hopefully. It's probably like 7kg weight.
Best to use two lathes.
Putting two screws into the same one can cause it to split.
Ideally, get longer screws and go right up through into the joist. Through plaster, through lathe and a good inch or more into thick wood.
Poke a screwdriver up in the hole at an angle and turn it to find the joist… I’d be surprised if there’s not one there. Old houses always had lights next to joists…
7kg is quite a substantial weight. You might need a helper to hold it up while you make the connections.
Oh brilliant mate thanks for that. Justin time before I was going to put the bracket up. The poking technique was really helpful. Now I've drilled in the joist !!!
Just realised the cables are in different colour in there. Twin n earth
I'm assuming the black is neutral , red is live and the earth is its standard colour.
Spot on.
But youll possibly find the light fitting has brown and blue.... or all white... which means it doesnt matter between L and N
As long as the earth is green and yellow :)
Reply to Putting a chandlier up in the Lighting Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
Blue? You haven't joined it completely back together! The copper screen around the wires needs to be continuous, ie you need to connect the two...
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
