B
BMW
Hi
Wonder if someone can help. I recently called at a job and the owner mentioned the MCB on a ring trips. Now he said another sparky had looked taken sockets off etc and found nothing. Thing is he thinks it's from 1 or 2 sockets in the kitchen and claims to have seen a flash from that area. Now it happens at all times of the day sometimes even midnight. It reset no problem then can be OK for day's or weeks the pops again.
I tested the circuit which seems to feed mostly downstairs but does have some upstairs sockets on the same circuity so it's a bit of a mix and found nothing.
Since then I have changed the consumer unit (separate job) and that circuit is now on a RCBO. Again tested and all clear. All fine for a week then guess what got the call it had happen again? Again reset straightaway and all fine. did it again the next day. Then fine for a week. Customer claims no appliances on at the time.
Spend half a day taking things apart and nothing. Customer wants it sorted but frankly I'm at a loss now. I can't find what I can't see and now customer is asking if I can rewire part of the circuit which could be a nightmare as I don't have fault to find and the house if full and lived in.
Any ideas?? It's getting where I'm testing the same thing again. Need someone to bounce some ideas off
