PV circuit Distribution or Final | on ElectriciansForums
Discuss PV circuit Distribution or Final in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
L
lumphammer
Does the dedicated circuit for a PV system count as a Distribution or a Final circuit?
Looking at the spec for the inverter most disconnect times are specified as 5 secs which implies a distribution circuit.
Reply to PV circuit Distribution or Final in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Regulations notwithstanding, the only thing in those pics that is likely to be affected by sheep is the trailing flexibles on the ground from the...
There is no reason for an item of fixed equipment to be on its own dedicated circuit just because it is fixed equipment. There may be other...
loz2754
L
