K
Kevin
OK, this may be an obvious question, but can a PV Installation be fed from the existing CU, if the CU contains an RCD, or would you be required to split the tails, and put the PV on its own MCB within it's own enclosure? Was told today by an NIC inspector that they require their own enclosure and RCD and cannot share one with other circuits, is this correct? Have read through the DTI guide and can't see a mention of this.
Many thanks
K
Many thanks
K
