I beg to differ, you need to match inverter compatibility which is crucial in any design. However all the main stream companies provide very good software tools for free. Then you come to working out the customers returns I have a very compressive model taking sap, est, pivgs giving various scenarios, the output of this is very impressive.
I then use a cad package to enter all the measurements taken from survey. You need Leica laser measure, you can not call it a survey without, anyone uses a tap measure customers should run a mile. Every aspect of the roof is measured including chimney,flues, roof windows and dormers.
Assuming no shading then use the to size panels and inverters. However if you are unsure about shading then you create a 3D model.
This is where no other solar design package will compare. I use Sketchup as my CAD package it will simulate location based shading on your model. I'm now an expert in the software and can not see how pvsol can give you the degree of detailed information. I know at 4pm the house opposite on 20 November will shade your array.
I've said all this before I use specific tools which will do the each task 100%. There are no predefined limits. I only yesterday designed schco mounting frames to check my row spacing for shading. I then use the same program to print the plans for planning. Really can you do all this in pvsol ?
I might upset the forum sponsor but I'm from a computing and accounting background so know all about software updates ÂŁÂŁÂŁ.
Ps Basic Sketchup is free !
