PVC capping and oval tube problems
L
LlandrilloSpark
Has anybody else had any problems installing PVC oval tube or capping?
I did a small kitchen rewire a while ago and used PVC oval tubing, the problem I had was basically the 2.5mm would not fit through it, it just kept getting stuck and I was using the correct size!
Then this week I'm doing a small shop so I decided to use PVC capping, it worked fine on the cable drops as I used a wall chaser to about 28mm then the capping pushes in nice and tight
The problem came when I needed to cap the cables running around the safe zone where ceiling meets the wall, the building is lime mortar and I couldn't get the capping nails to hold anywhere, I even struggled to fix the cables as I had to result to the large headed galv clout nails either side, nightmare.
Unfortunatly I just had to leave them exposed, they are at 20mm deep I'm just praying the plasterers go easy today.
I would of prefered to run everything in the ceiling but it's an old lathe plaster ceiling, very unstable and the client wanted minimum damage to it
LlandrilloSpark,
Sintra,
TrueNAS JBOD Storage Server
