PVC Conduit size for 1.5mm SWA | on ElectriciansForums
Discuss PVC Conduit size for 1.5mm SWA in the UK Electrical Forum area at ElectriciansForums.net
RDB85
Trainee
Liverpool
What PVC Conduit size would best for 1.5mm SWA 3 Core? As I need to run some inside conduit.
Why put it in conduit???
Needs to go up a wall and into a sub main CCU.
[automerge]1601667703[/automerge]
He needs a hole to put it in. Lol
[automerge]1601666862[/automerge]
Put in 25mm should be OK, but why would you put it.
Would 20mm be okay as I’ve some left over from another job. Don’t mind buying 25mm
Could do. I’ve got to go around a facia with some conduit as I can’t bury the cable. Then along some fences with some cleats. Don’t fancy a black cable on a white UPVC Facia.
use the conduit clips, not saddles, on the fascia. and 20mm tube will be fine as long as no tight elbows..
I will have a look at the conduit clips. Not seen them before. There is one bend which I’ve decided to use an inspection bend as it’s the end of the garage wall as I made a 90 bend and it’s not as tight and doesn’t look right. Using a prefab bend I think in this case would be better. Thanks for the help Tel. ??
Reply to PVC Conduit size for 1.5mm SWA in the UK Electrical Forum area at ElectriciansForums.net
Came across 3No 1ph heaters connected by 2xT&E cables from a 3phase supply on an installation whilst carrying out an EICR few years back...
Of course, showing my age now!
