The cable itself has the cores insulated with compacted magnesium powder,they will take one mighty hammer blow to even damage that insulation
If you bend the cable,do so with a sweep rather than try and do an instant 90 degrees (which will probably collapse the outer copper sheath),there is a tool for making the bends but using a bit of rounded wood will do
The pots on the end are star crimped with a soft compound insulation,they do not like being disturbed,so any movement needed should be elsewhere other than the pot
It is possible to remove the gland and pot and re use if you take care,however,the potting compound would need renewing,so best have some handy if you are ever going to dismantle,without the correct tools it would be difficult for a newbie to terminate,however,the stripping,potting and crimping can be done with hand tools if needs be
