QS and electrical Installation certificates | Page 2 | on ElectriciansForums
Discuss QS and electrical Installation certificates in the UK Electrical Forum area at ElectriciansForums.net
Pete999
Northampton
Here's a first, I have a question regarding Domestic 3 signature EICs, not having much to do with Domestic for a very long time way before the onset of the introduction of the QS, as I understand it the 3 signatures required are: the Installation designer, the Installer and the QS, before the QS actually signs off the cert, does He/She have to carry out any testing? or is it just a case of checking the cert to ensure it has been filled out correctly?
The only reason that they managed to keep in the scheme was they could see that I was trying. In the end it all came back to bit him.
Just goes to show that you can be a lone cowboy and get away with it or you can be a posse of cowboys and still get away with it, about time the CPS took a good look at themselves and got their act together, imo
Can I take this thread a different way slightly for a minute, but based on a theme that has already been mentioned in brief. The model forms state they are for installations up to 100A - in the work I've been involved in this has been sufficient but what forms are used for bigger installs? Has anyone got a 100A+ model form, and where would they typically be used?
So in effect if what you are saying is the norm, the QS is the fall guy should the brown stuff hits the fan?
This is where the good habit of getting everything in black and white and storing it for future reference comes into play.
Also going around and auditing sites during works and on completion not only ensures the work is being done correctly but also enables me to identify the less conscientious employees and apply a little more pressure on them to get the job done correctly.
My arse is covered if anything does go wrong. It pays to be proactive and be forceful with the management. It does take a lot of hard work to keep on top of things, good job I don't really care about upsetting management... ;)
Good for him
just use the standard electrical installation certificate.
The single phase 100amp ones are just less pages for the full scope single phase brings.
A valid point Strima, problem is that there are some unscrupulous managers out there, "toe the line or look for another job" and jobs are few and far between these days. You might say not these days employment protection and all that, that' OK if you work for a large employer who doesn't want an unfair dismissal tribunal hanging over them, but believe me if you rock the boat there are ways of getting rid of a, shall we say trouble maker.
You mean this one? That states it's only for use up to 100A?
[ElectriciansForums.net] QS and electrical Installation certificates
Reply to QS and electrical Installation certificates in the UK Electrical Forum area at ElectriciansForums.net
It applies to commercial if it shares the same supply as a dwelling.
I usually put something like this To assess compliance with BS7671 for continued safe operation (5 year periodical inspection)
Recommended Sponsor News
Hi everyone,
