dylanoil
Thanks for all the comments (constructive and otherwise!) I also came across the paragraph below in a inspection training book which probably summarises it nicely. Andy - I think you are right in that it could be a long conversation with the LABC. I might just do it for sport!
Unregistered competent person
If the work is carried out by a non-registered competent person who is capable of completing the correct certification, the localauthority will need to be contacted before commencement of work, and the work will be carried out under
a building notice. This will involve a fee being paid to the local authority and a visit or visits being made
by a building inspector to inspect the work being carried out to ensure that it meets the required standard
(the cost of this will usually be far higher than that charged per notification by a scheme provider to a
registered installer). On satisfactory completion, and after the issue of the correct certification by the
competent person, the building inspector will issue a completion certificate. The issue of a completion
certificate by the local authority does not remove the responsibility for the work including guarantees from
the non-registered competent person; the required certification must still be completed by the person who
carried out or who is responsible for the work.
