Hi macsparky
i have read the threads you have linked to !!!
I have city&guilds 2330 level 2 and level 3 and 2382 17th edition
does this just cover domestic only
thanks Rich
Domestic, commercial and industrial my friend. Surely if you have these quals you must know what you covered at college?
thanks for response cirrus .yes i understand three phase and can inspect and test industrial but i have mainly worked with a niceic guy on domestic .I am going for a domestic installers scheme ( niceic ) will i still be able to legaly work on industrial with out a nvq level 3
thanks Rich
As far as i know there aren't any real pre-requisites apart from bs7671 and 2391 for testing/working on commercial/industrial work, i think the nvq3 is one of the requirements by jib to be recognised as an approved electrician:rolleyes:....bit of a mine field really and this was also discussed recently, im sure someone will correct me here if this is wrong:D
Thanks macsparky
the information is very helpfull to me at least i know giving up my saturdays for three years was worth it ( I attended chelmsford college on saturdays )
Rich
Its a hard life these weekend and evening classes. I'll be done with my 2330 lvl 3 in a week or 2. Then will have to do 2391 and 17th. Both only 10 weeks or so. So nearly there
Keep it going danzor, surely you can almost smell the money now;) i too have the 2391 in july (pants becoming slighty soiled over this one) lol....:)
Same as me Danzor - can't wait now:cool:
there are no pre-requisites for anything
only thing required is COMPETENCE
no-one needs the 2391 to test&inspect, however individual organisations (NIC etc) may require you to hold it to do PIR's under THEIR name (and paperwork) although there is nothing to stop you doing them on generic forms
Most employers require applicants for electrician positions to have experience. If you are a fresh graduate from an electrician school, you may have some problems. The best way to earn experience in your field is to undergo an apprenticeship program. :D
__________________
He Who Is Afraid Of Asking Is Ashamed Of Learning
[Electrician Schools | Electrician FAQ]
So you don't NEED 2330,2391, ABCD, etc Shakey?
Who classifies you as competent?
I know you've told me this before but I have a crap memory
what i said was you dont NEED 2391 to inspect and test
trouble is, if you are going to work for anyone, join a competent persons scheme etc etc, that competence is firstly defined by quals
Most people will define their own competence
Heres an example Bane:
If i asked you to change a 40W bulb in my living room do you consider you are competent to do it (please say yes:p)
then how about taking on a contract to design install test and inspect the entire olympic village being built (please say no:o)
Ok, you you will sit somewhere in between, and you know what you are happy with
ask the average guy who does Periodics in houses if he fancies doing one for his local Asda or tesco, and he will probably turn a shade of green
So in answer to who defines your competence - most of the time YOU do;)
and how do you prove competency prior to commencing any work .Photos of previous work doesnt count:D
and thats my point Wayne;)
2391 is a classic example
it is not a pre-requisite to hold 2391 to do PIR's
but without it who would take you on doing inspecting and testing?
And i am not saying holding 2391 , or any other qual, proves competency
but it gives you a head start dont it?:rolleyes:
Help
I would like to join niciec as a domestic installer i have 2330 level 2 and level 3 and 17th edition The question is i want to work part time only as i have a full time job. working p/t (weekends evenings holidays ect) being a mature student i have lifes exsperiances and have worked with sparks over the years part time is it true that if i join niceic i have to be trading for 6 months or can i become a member by showing my competance with 2 installations and showing competance in the regs and visual inspection& testing
you generally have to be trading for 6 months as well as the two jobs etc
why not just use the LABC and not join a competent persons scheme until you are more established
thanks shakey
Shakey
I have a consumer change to do in a flat.Please explaine what will be the 1st steps about contacting the local council,do they visit 1st and i will be using the electrical installation certificate photo copyed out of the regs
go on their website and download their building notifiaction form or pick one up from them
submit it them along with the fee
complete job and send them a copy of the certs - they will tell you if they want anything else doing
Hi shakey
does the inspector visit before any electrical installation commences or do they check after inspection and testing and certification of the installation. are they sparks that turn up and do they just want a quick look at the work and want to check your test results.WOULD
Hi shakey
does the inspector visit before any electrical installation commences or do they check after inspection and testing and certification of the installation. are they sparks that turn up and do they just want a quick look at the work and want to check your test results.would
would they know a good or bad result on the test forms ie zs for a ring final being to high according to bs7671 17th ed
depends on you, depends on the job
I teach my students to build a rapprot with their LABC
many notification forms ask you your quals etc, obviuosly 'joe nobody', if doing the electrical work is going too come under more scrutiny than a fully qualified sparks
as regards paperwork, I teach people to fill it out as if mr 'top sparks' is gonna read it, personaaly i could spot a 'made up' certificate easier than i could spot Frank Bruno at a KKK convention
they may send someone in to check your work, they may not, much depends on you
as regard the 'inspector', there is no remit for him to visit before any electrical work commecnces, but if the installtion was part of a bigger building project, such as a new build, you can expect the normal building control visits at varying stages of the project, including a check of the electrics, such as a pre-plaster check
only form i can find on my local council web site is a building notice is that the one i need ? only other form is a full planning notice
yep thats right
it will generally be a building notice if it just an electrical job, it would be full plans for something like an extension (that included electrics)
I have had email from local council today and the will send local electrical contractor round to check work.price quoted on council site is £60.00 is this correct.On minor works do i submit test form to local council:)
sunny essex
qualifications ???
Talk Electrician Forum
tuckermot,
tuckermot,
