Quality!!!!!! | Page 2 | on ElectriciansForums
Discuss Quality!!!!!! in the Talk Electrician area at ElectriciansForums.net
salmonella sushi with crispy fried plastic
Tony why would I offer to install an additional socket. So they can put another 4 way socket outlet in it? By putting commando sockets in each appliance has its own individual supply, no additional items can be plugged in to overload it and it is also better for cleaning. As this is a commercial property it has a 20% eicr carried out each year.
Surely the problem here (apart from the dirt and using the multiway adapter) is that the plug is badly wired or with dirty pins and the resistance is overheating the pin of the plug and melting the socket.
If the appliance were taking too much current the fuse would blow in the plug and it seems unlikely (unless they were loosely plugged in) that all three outlets were faulty.
Another Friday the 13th job , were your shoes stuck to the floor and hands all greased up ,,
Tell em to clean the place up and maybe you might go back....LOL...
You can’t do that!
There’s money to be made by conning the customer.
Although it sounds like the customer is wise to his tricks.
Reply to Quality!!!!!! in the Talk Electrician area at ElectriciansForums.net
U
Taps: quality tiers? Hello, I've tried searching using Bristan, Grohe, Vado etc & get no results at all - I don't understand that! Anyway, is...
UserError
U
L
What manufacturer makes the best quality fittings for multilayer pipes? What manufacturer makes the best quality fittings for multilayer pipes...
LordWest
L
