question 6 in current design | on ElectriciansForums
Discuss question 6 in current design in the UK Electrical Forum area at ElectriciansForums.net
southall
calculate the desgin current of the radial circuit suppling the air compressor ( circuit BR4)
i need help with this ASAP please
As per @i=p/u you’ll need to know the current rating of, in this case the compressor at the end of your proposed circuit, they must’ve given you some numbers to work with?….can you share them with us?
As above, you should have been given more info for the question.
Also, when you find the full question, we would like to see what results you get. If your result is incorrect we can help you with that. Us just telling you the answer is now a good way of you learning.
Reply to question 6 in current design in the UK Electrical Forum area at ElectriciansForums.net
I have a question i hope someone can just give me a little clarification on . When carrying out preliminary cable design for a given circuit we...
What kind of a socket? 13A, 16/32A commando, etc? Single socket on a radial, or multiple sockets off the same circuit?
