Question about earth wire - photo attached | on ElectriciansForums
Discuss Question about earth wire - photo attached in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
UK
An electrician noticed that the clamp on the earth wire in my house wasn't right while he was fixing an unrelated fault. He called the power company because they have a legal duty to fix it. I noticed that the guys from the power company have used tape instead of a clamp and wondered if this is acceptable?
Thanks.
[ElectriciansForums.net] Question about earth wire - photo attached
There could well be a clamp under the tape or as above it's been sweated on
Also....get that earthing conductor checked pronto! Earth fault current will be unsure where to go and won't know it is allowed to flow through it as it's splendid green/yellow markings have been painted over in emulsion.
Reply to Question about earth wire - photo attached in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
2 3
Thank you so much for your help with this light work perfect now thank you again much appreciated
