Question about Economy 7 hot water cylinders | Page 2 | on ElectriciansForums
Discuss Question about Economy 7 hot water cylinders in the UK Electrical Forum area at ElectriciansForums.net
England
Hi
I recently replaced the bottom immersion on an economy 7 cylinder. After installing I tried to test the immersion using my multi meter. The fuse spur leading to the immersion has a time clock mounted on the face. I switched this to continuous, nothing.
I removed the face of the fuse spur / time clock and checked for power in the patress box. Nothing.
My thoughts are either the breaker had blown or the fuse spur only comes live during the night, on the cheaper economy 7 rate.
I've recommended the landlord contact an electrician. I'm a plumber, I've done the wet work draining the cylinder and fitting the new immersion.
I've mostly worked on new installations or in-direct cylinders.
Reply to Question about Economy 7 hot water cylinders in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
This is an RSS feed of thread: Two electrical supplies and a single immersion element Content of the thread: Good afternoon, new joiner here with...
