A
abuameer
Hi all,
This is my first post. I have just purchased an electric oven which is rated at max of 3200 Watt. Currently my kitchen has a ring circuit with MCB of 32 Amps. Is it law that this oven has to have its own radial circuit? doing the maths : 3200 / 230 = 13.91Amps. No way near the 32 AMps but i understand that kitchens tend to run high rated appliances such as toaster, washing machine, kettle etc and there may be a point in time that it could use up the 32 Amps. If it is not law that it needs to be on a separate radial circuit then is it possible to increase the 32 Amps to 40 Amps say? Thanks for all your advice.
Regards,
Abu
Regards,
Abu
