Question About The Electrical Feed for A Shower??? | Page 2 | on ElectriciansForums
Discuss Question About The Electrical Feed for A Shower??? in the UK Electrical Forum area at ElectriciansForums.net
Pete E
N Wales
Just a quick general question about the Regs ect concerning electric showers...
I am tracing some redundant but still live wiring in my house, more out of interest in how it has been wired than any other reason.
The house was built in the 90's and has the old colour wiring scheme.
When built, it had a hot water tank and immersion and an electric shower in the main upstairs bathroom, plus a second electric shower ensuit in the main bedroom.
At a later date, most of this was removed and a combi boil was fitted and the showers are now part of that system.
I have found the radial that fed the original immersion and it is still live but having traced it, I suspect the same radial was then used to feed the electric shower in the main bathroom?
Just wondering if that was a common/permissible method given the amount of potential current draw?
Regards,
Peter
I got up in the loft last night and had a look around under the insulation and was able to find where the switches had been from the remains of holes and plugs ect...
Scouting around further and knowing where the showers would have been I was again able to find holes down into the partition wall...It looks like all the cabling was recovered so I am going to call it good and leave things at that...
Reply to Question About The Electrical Feed for A Shower??? in the UK Electrical Forum area at ElectriciansForums.net
S
Unidentified noise in party wall Hi 🙂 Please can anyone help to identify this noise in the wall between me and my neighbour? Complicated but will...
shrewmouse
S
By the time you've dealt with isolator valves that won't shut off and drain valves that won't open, half a day will be gone before you've removed...
