Question - I want to change the use of something... can it be done? | on ElectriciansForums
Discuss Question - I want to change the use of something... can it be done? in the Australia area at ElectriciansForums.net
G
GirlRacerRed
boys,
I have a question.
I currently have a wall mounted ventilation fan in my main bathroom. it doesn't vent to the outside cos the numpty builders didn't bother to knock thru to the outside.
upon testing the fan, it doesn't work and I want to remove it completely. It's wired to a double switch (with the bathroom light) outside the bathroom door.
If I disconnect and remove the fan, could I re-route the existing wiring and bring it up into the loft and run a regular light fitting from it? Essentially so that I can put a light in the loft, as there isn't one already.
Thoughts and comments appreciated.
Liz :)
I'm not fitting anything in the bathroom. I want to pull the wiring out of the bathroom and back up into the loft where the wiring is run from.
I want to disconnect and remove the fan and fill the hole that's left. No more fan, no more ventilation apart from the window until the shower is fitted and a new fan/light jobbie is fitted.
Hi all
sorry to hijack this thread but i have a similar question?
my parents are changing there central heating system from a back boiler to a combi, the new boiler is going in the airing cupboard in the bathroom ( special location ) but can the wiring for the extinct immersion heater be used for the new boiler with out any coffullall ( not sure of spelling? ) ie i know there earth bonding is not up to date and the CU is really old, i intend to update when i gain my 17th and use has an install to register with governing body, just want some advise before the plumbers spark comes round huffing and puffing.
Parents are in there 70s and could be really easally conned?
thanks in advance
Graham
Reply to Question - I want to change the use of something... can it be done? in the Australia area at ElectriciansForums.net
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
