Question on carrying out Zs testing. Please Help. | on ElectriciansForums
Discuss Question on carrying out Zs testing. Please Help. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
N
nazoom
When carrying out Zs test for a particular circuit lets say Socket, what happens to the RCD protecing that circuit does it have to be ON or OFF? I know that the socket under test must be On and I know it is a live test.
Many Thanks.
Many Thanks.
You've answered your own question, it's a live test
So the RCD must be On!! Is it possible that the RCD might trip when doing the Zs test? It is a domestic installation?
Heavens! This is a bit fundamental mate, it's a live test, so you must have a supply available at the socket therefore if the final circuit is RCD protected the RCD must be latched in the ON condition. Normally in order to do a Zs test the meter will need to be set on a No-trip range to prevent the RCD tripping under test.
nazooms been blagging free homework with vague questions for weeks
well im hoping its coursework and he hasnt been let loose on the general public yet ;-)
Reply to Question on carrying out Zs testing. Please Help. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Not all sockets isolate both the live and neutral when you turn the switch off Many just isolate the live leaving the N connected. So the...
He is after the four options for 1 and 2 of the multiple choice exam, probably optimistic someone will know this. Your question 3 in incomplete to...
