sambuca2907
Hi all - just wondering if I could get some advice.
I have installed 3 new circuits in an extension - a kitchen - lighting, ring main and cooker (gas so just 13A elec start). The existing board only contains MCB's, and my new circuits need to comply with 17th edition regs, so need RCD protection throughout.
The existing board is a nightmare... the electrics in the house I have come across are condemable so I have no wish what-so-ever to touch these! The guy who lives in the house "did a bit of electrics" years ago... so has done his own additions over the last 25 years...! I took the cover off a light fitting and found SIX lots of 1.5mm going into this... mangled together with choc-blocs and tape!! If I replace the existing board I just know I'm going to have earth leakage everywhere and never find the problems, so going towards putting in a new 17th edition board to cover the new circuits.
The question I'm asking is do you think it's better to do the following:
- Run 6mm from a 45A MCB in the existing board to the new board, and link back to the main earth terminal (Distribution circuit)
- Remove the tails from the existing board, add in Henley boxes and run a new set of tails to BOTH boards... abviously this option is going to cost more which I'm reluctant against as I've already priced for the job without this in mind!
Any help please?!
Any help please?!
