So if the Live and Neutrals both share the same cross sectional area, then is the length of the circuit for calculating the circuit volt drop, the length of the cable run out to the last circuit load- so referring back to my example, 15m and not 30m?
What if the Live and Neutral conductors have different cross sectional areas- for example a 2.5mm live and 1.5mm neutral? Would you have to use two different mV/A/m values for the live and neutral conductors, and would this make the length of the circuit for the circuit volt drop calculation include the length of the Neutral conductor running back to the consumer unit?
