questions for installation cert | on ElectriciansForums
Discuss questions for installation cert in the UK Electrical Forum area at ElectriciansForums.net
glasgow
Hi ,
Could someone answer the following for me? i don't have reg book handy and when i google i'm getting mixed answers.
1. maximum disconnection time for a type A rcd on a consumer unit at times 1 setting?
2. on a ring continuity test the readings i measured and put on cert were L-L 0.36 N-N 0.29. I have been told this is unacceptable as the difference can't be more that 0.05 ohms between L-L and N-N. Is this correct and if so where would i find this in the regs or onsite guide?
1. Assuming it is 61009 or 61008 then 300ms.
2. I don't believe there is a requirement stating this but morevrule of thumb. Your readings do warrant some investigation.
The 0.05 ohms comes from the OSG, I have not seen it in the regs book. Certainly if the readings obtained were for intial verification tests as suggested by the thread title they would not be acceptable, I would not be overly concerned however if these readings were on an existing circuit as part of an EICR.
Reply to questions for installation cert in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
