Quick continuity question | on ElectriciansForums
Discuss Quick continuity question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
J
JakeC
I'm studying the the Inspection and Test exam and just ran a continuity test between L + N on a downstairs lighting circuit and got the result 62.9 Ohms. Is this in the ball park as I'm not sure what figures to expect.
Check the lead resistance of your leads on your test instrument, This is quite a high reading, make sure all terminations are tight but dont overtighten. I often get around 1 ohm on a lighting circuit at the furthest point. What readings u getting between l+e and n+E?
0.25 ohms through the test leads. It's 69 between line and neutral.. I'll check neutral to earth tomorrow it's getting dark now
Ah I've realised now what I've done wrong. I was measuring at the consumer unit D'oh. (first day practical)
Is this right..
Tempory link between L + N then measure at all switches and take highest reading? Then do the same for N + E?
Are you sure you're not after (R1+R2) mate? I'm at a loss to understand why you're carrying this test out and what you hope to achieve by it
That is what I am doing starting with continuity then moving onto IR think I've just got the 2 mixed up abit. I am after R1+R2 so L+E?. Sorry for the confusion getting ahead of myself.
When you're done playing with your test kit:) get your head into GN3. The more familiar you are with it the easier the exam will be
Best of luck to you for it
Reply to Quick continuity question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
The instructions tell you to test the insulation and you already know from the result of the previous test that the L and N are not insulated from...
davesparks
Excellent :-) The case and leads are in good condition. Two live leads, one with a test button. Looks like ÂŁ30 well spent.
