Quick continuity question | Page 2 | on ElectriciansForums
Discuss Quick continuity question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
R1=L R2=CPC link together in CU and test along the circuit the highest result being the one you record
Reply to Quick continuity question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
The instructions tell you to test the insulation and you already know from the result of the previous test that the L and N are not insulated from...
davesparks
