Quick Help! Switch only switching one spotlight off! | Page 2 | on ElectriciansForums
Discuss Quick Help! Switch only switching one spotlight off! in the UK Electrical Forum area at ElectriciansForums.net
N
NathanMorgan
I'm changing 4 spotlights over to LED and the spotlight which has all the switch wiring in is the only one switching on/off at the switch.
I have identified the switched live but I am obviously missing something as the other 3 are permently on and will not be switched off at the switch.
Any guidance is much appreciated.
Hi Nathan: Sorry that our replies didn't meet with your expectations. Pete and one of the other sparks that took the time to reply, Did actually tell you what the fault would be.
Also as Kenny pointed out: As Sparkies we have a Duty of care to you, Not to give you information that could cause you Injury or worse Death.
By your own admission you were trying to fault find on a circuit without any test equipment, just using a hit & miss approach.
That's an Amateur & Dangerous way to do it.:eek::mad:
Reply to Quick Help! Switch only switching one spotlight off! in the UK Electrical Forum area at ElectriciansForums.net
Thanks guys, I'm going for the safe option and take your advice in getting a qualified electrician to look at it. We've inherited these issues so...
Hello, Last year my 30 year old Static Pase convertor stopped working, the 3 phase motor is 0.55KW / 0.74HP and drives a small lathe. When I...
