B
Besoeker
For Tony
Cheers, that will help or confuse others. But they can see what we’re talking about.
We used them on stone crushers, as a conventional starter they’ve got the grunt to get a blocked crusher going. For stone sizing the speed is then varied, a slower speed gives a larger particle size.
I had a thyristor pack fail on a 2500HP fan. When the pack fuse blew it put the fear of god up me, I was stood near it.
Essentially switching devices, they are either on or off.I think I need to brush up on my theory, I had only come across thyristor's In small low voltage cases in electronics
if I remember right don't they only let a set voltage through and disparate the rest through heat?
(edit it's coming back to me from my 2330 at college, my lecturer really like his motors etc)
The first GEC Kramer drives I worked on were installed in 63.
The one that failed was about 90 again GEC designed.
They had had failures before, non with such spectacular aftermath. Swapped the pack out and switched back to speed control, no problem.
Tested the thyristor in the shop, no fault found?
Got admit one of the beauties of the Kramer system is being able to switch seamlessly from one setup to the other. It’s a bit weird knowing that the drive you’re safely working on, the motor is still running.
Reply to the thread, titled "quick motor check?" which is posted in Commercial Electrical Advice on Electricians Forums.
