quick one
domestic spark
if in the intake to a building, its tn-cs pme three phase, then from that you have meters and to each flat you have 2 core armoured, and earth off the shiefing, is this a tn-cs system at the orign of the flat cheers!
obv, mark! you couldnt just run anything!! aslong as your within your cables limits, i thought using earth strands was fine? as long as your sure srrands wont get damaged/rusted, and you loose your earth reading! open to corrections
its like when you run armoured, and use a core as earth some say oh it has to be 16mm if your supple orign earth at the MET is 16mm. where as this is NOT the case.
