Quick question about bonding! | Page 2 | on ElectriciansForums
Discuss Quick question about bonding! in the UK Electrical Forum area at ElectriciansForums.net
DNS1
Hi chaps,
Just did a "mock" EICR on a friends place and found no bonding to incoming gas and water.
Am I allowed to use a single piece of 10mm to bond both of them back to the MET, or does it have to be 2 separate runs? Fairly sure 1 run is ok, but just wanted to be sure!
Sorry for the amateurish question!
There is no limit for the resistance of main protective bonding.
got me worried then, i haven't heard of this reg either but then again ive only just got around to ordering bgb and on site guide.
i have got outside lights to do
change cu
wire in cooker( without 1 for a year now)
sockets to island and switches to lights
she just told me she wants decking outside and build a front drive gate
finish off on suite in one bedroom
put together childs playhouse
getting depressed now, a million other things as well.
and i ask her to lie on her back for twenty minutes and guess what response i get!,,,,
maybe 10 minutes
I'll admit I was under the impression that
0.05 was considered effectively the same....
Gn3 suggests it should be around 0.05
I can see why 0.05 for earthing conductors, am
Now questioning myself and the NIC inspector.... Lol
Ask him to show you the regulation, then take a seat and watch him squirm out of it!
If he mentions GN3, ask him why it says 'between metallic parts' if it's referring to main protective bonding which would by definition only be installed from the MET to an extraneous-conductive part.
now on the subject of the adiabatic....i was aware of its use for earthing....but also was under the impression that it could also be applied to bonding.....
Not directly but on a non-PME system the bonding can be sized from the earthing conductor which can be sized from the adiabatic.
I was just thinking it needs to be the same potential.... I.e 0.05, like r1 and rn conductors in a RFC.
I was told it had to be 0.05 on my 2391 also, just been looking through
My Notes for the reasoning why..... Lol.
Can't find anything!
Reply to Quick question about bonding! in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
The power company only brings in 3 wires which is 2 live and 1 neutral wire. It’s our responsibility to add the ground rod to bond the neutral...
