quick question.. reference voltage | on ElectriciansForums
Discuss quick question.. reference voltage in the Australia area at ElectriciansForums.net
G
gaz2212
anyone no where in the 7671 anyone can find a quote or reg regarding reference voltage...
the question is
what conductor gives a known volage or reference voltage???
the question is
The answer would be the neutral conductor - 0 volts:)
I don't know if it's mentioned in the regs, but the reason is it's 'referenced' to earth (0v) at the star point in the transformer.
Is that the full question?
Only reference I would use would be Earth!
e.g. How would you prove polarity at a TN-C-S supply point. ( No volt stick )
Ans. Sink a Earth spike and bring a lead to the point of test.:cool:
Reply to quick question.. reference voltage in the Australia area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
