Quiet contactors needed for some 20KW fan heaters | on ElectriciansForums
Discuss Quiet contactors needed for some 20KW fan heaters in the Commercial Electrical Advice area at ElectriciansForums.net
UKMeterman
Hi,
I am looking for some quiet contactors to control a pair of 3 phase 20KW fan heaters in an art gallery. Are there any favourite suppliers?
Don't fall for hagers 'silent contactors'. Seen someone fit them and they are exactly the same as normal one. Turns out the silent is the 'hum' that most new contactors don't produce anyway.
Why would you need to label the local isolation.
Because everything has to be decorated with stickers these days to make it look pretty!
Even the NICEIC womble who came to visit last year wanted me to start putting 'danger 400V' stickers at regular intervals on the lid of trunking in case someone didn't realise there were cables in there 😂
Where do the stickers stop? The 2 colours one is a joke, if you don't know why they are those colours close the lid and pi$$ off. There is vert rarely a need for 400v stickers either yet I see them plastered on isolators and boards all over the place
the idea is to put them on just in case a blind man with tester dont see them 😱😱.
Guilty as charged, I have put L1, L2 & L3 stickers on 240volt socket outlets where distributing single phase from a three phase board especially when you only have a 12Kv supply and the tumble dryer and washing machine are side by side.
I would be looking at something like this.
bear in mind that when solid state contactors fail, they normally fail in the “closed” state.
it may be necessary to back it up with a normal contactor on an over temperature stat to prevent the element from overheating if the solid state fails.
Maybe also worth mentioning that solid state devices shouldn't be used for isolation.
Reply to Quiet contactors needed for some 20KW fan heaters in the Commercial Electrical Advice area at ElectriciansForums.net
Thank you for the suggestion!
Thanks pc1966, never heard it called that before.
