quietest 4" extractor fan with timer | Page 2 | on ElectriciansForums
Discuss quietest 4" extractor fan with timer in the Electrical Tools and Products area at ElectriciansForums.net
X months down the line, fan still virtually silent, no rattles and well made, plastic feels stronger than most and wiring inside is well laid out, only one gripe, I wish they would stick a knock out in each corner, so you could avoid either drilling a hole or having the writing vertical or upside down, depending on what someone has done in the past...
Did the manufacturers instructions of this fan spec 3amp supply.? And have you put it on 3A fuse.?
No need with the envirovent. One of the things I like most about them. The MI only state that the connections must be made through a double pole switch with a contact gap of at least 3mm.
Reply to quietest 4" extractor fan with timer in the Electrical Tools and Products area at ElectriciansForums.net
