O
aye but insist that its no good for continued service.....as we`v just had the runround from a DNO over an earth issue...both this and that should be a priority for em....hmm we`l see....lol...Might do that after I've changed the CU on Monday!!
that was the word I was trying to think of, thxVerdigris.
Hi Howard, how and where would you record the fact that the main fuse cannot be identified then?
On and industrial install i did the DNO fitted the same rated fuses as my 200Amp BS88 (type 2) but was told discrimination wasnt lost as he had fitted type 4's..... not sure if this happens in domestic though or whether it actually does achieve discrimination in a fault.1361 60A is my guess as my house runs on exactly the same piece of tosh on the first cut out which then feeds an 80A BS88 cracking bit of discrimination!
Industrial 3phase main 200A isolator feeding busbar fed from their ISU, you have to have independant fusing when supplying 3phase and cant rely on DNO fuses unlike domestic where DNO fuse protect accumulative load of all circuits from overload of your dist board.they know mine is wrong as they are changing it on the 7th of next month! why would you put one cut out feeding another!
I'm talking domestic here hence "my house"Industrial 3phase main 200A isolator feeding busbar fed from their ISU, you have to have independant fusing when supplying 3phase and cant rely on DNO fuses unlike domestic where DNO fuse protect accumulative load of all circuits from overload of your dist board.
Reply to the thread, titled "Quiz" which is posted in Australia on Electricians Forums.
