F
Festerfly
Yes i know there have been a lot of questions recently asking for advice on what to quote but i thought i would just add to the number?!?!?!?
Basically i have been asked to re-wire a kitchen for someone and although the practical side is not new to me, the pricing for this type of work is..
Basically here is how it looks so far:
Current kitchen has 3xdouble sockets and 2x lighting circuits. New plans (inc new kitchen)require the following.
1) Split exisiting Ring and install 5x Double Sockets. Surface mounted behind cabinets but chased into wall just prior to worktop height and then boxes sunk at or above 150mm from top of worktop. toal cabling req estimated 8-10 metres (large kitchen!) Walls to be covered by glass splashbacks once kitchen installed so no need to make good.
2) Take exisiting wall mounted light feed and remove exisiting luminaires (x2), crimp cable and extend behind wall cabinet location and locate for undercabinet lighting. (chase required for around 1Metre)
3) Extend exisiting fused spur for Cooker hood by 1.5m and chase into wall and socket.
4) Add 2x spurs from main ring for Fridge and dishwasher. Surface mount.
5) Run feed from exisiting ceiling luminaire(2M) and install new switch feed circuit to current wall mounted light switch location(4M) (and convert to 3 gang switch). Ceiiling is Lathe & Plaster so will require Carpet & floor boards up in above bedroom.
6) Run new Cooker power feed (cooker is rated at 15A) from D/B located at the other side of the house Will require lifting of landing Carpet & floorboards and cable run alongside new boiler in the kitchen due to solid oak flooring located in the main downstairs hallway and Kitchen. All surface mount once in kitchen and swithc fitted in adjoining cupboard (customer wants only sockets availble so all fused switches and such must be internal cupboard surface mounts) Total length of 6mm feed estimated to be 12-15 metres due to convoluted route.
7) Install RCB on RCD side of Hager D/B. Current RCD is rated at 63A. Should this be upped to 100A also as its also sharing this side of the board with the Electric Shower and a few other main circuits (ring etc)? RCB Rating to be 20A for the Cooker?
Im estimating around 1.5-2 days work for this as im on my own. Is this fair? Nad what sort of price do you think i would be looking at in labour terms?
All the current Bonding is suitable and the board was replaced fairly recently and hasa couple of spare slots on either side of the split etc.
Materials would be at cost as i dont beleive in marking them up. Pricing this job right is important as there could be lots more work available thought this client and referrals etc.
I would apprecaite and help you could give. I am located in Bedford if that makes any difference to pricing.
Cheers
Lee
i know its only been a couple of hours but wondered if anyone had any rough ideas.... got to knock this quote up for tonight,
ta
Cheers
Lee
ta
